I have a Dell Vostro at work (I know, I know)...
The issue is that I have a Radeon HD 2400 Pro installed as part of the 'graphics upgrade' which works a treat for two monitors.
The trouble started when I started to need a third monitor.
Having tried a cheap PCI graphics card (I soon found that trying to get a PCI graphics card to work in Windows 7 64bit due to a signed driver issue was a waste of time), I opted for a PCI-e 1x graphics card from Matrox.
Turns out that the card doesn't even initialise - at least it doesn't show up in Windows at all and it's as if I've not even plugged it in.
I am starting to assume that it might be a hardware limitation and you simply can't run two PCI-e cards at the same time.
Does anyone have any advice that doesn't involve me spending £300 on a 4 port gfx card?!
