Hey guys
A fairly quick question, but I'll probably make it into a long-winded description, as always, bear with me
Basically I want to have a small network comprising both wired and wireless elements, and have multiple internet connections available through the network.
It's mostly for learning purposes, but I figure it could come in handy in some ways.
Essentially I've got:
ADSL - (Wireless Router/Switch/ADSL modem) - other computers
And another laptop, which has a 3g connection and can also connect to the wireless network. To use this 3g network, is it as simple as turning on "inernet connection sharing" or whatever it's called?
Also, how would that work with there now being two seperate connections running? Would computers use the fastest link, just the router, whatever link is available, etc? Would this work the same if I had a cable modem and an ADSL modem on the same network?
Finally, if (in theory, and assuming it wasn't against the TOS of the ISPs) I had two ADSL modems in neighbouring houses, and their wireless networks were the same settings (ie, the same wireless network), would this work the same?
The latter is more of a useful excercise for us, since we've got two university buildings nearby, using the same network, but each have different downtime for "scheduled maintenance" - we were considering building some resiliance of our own into the network by combining both building's connection, so we can use whichever's is up.
Okay, that ends my long-winded explanation... thanks for any input
