Multiple ipods
24 Mar 2004
Northern Ireland
Two questions:
1: If i have 2 ipods can i have differant music on them, while using the same version of itunes to manage them? (Without having to reselect everything each time)
2: Can i get the bbc iPlayer shows onto an ipod shuffle (bbc radio1 podcasts) - The actual shows, not the crappy podcasts on itunes.
1) Yes.
Set up Playlists for each iPod and then in iTunes set the Summary tab for each iPod to Sync only checked songs and videos and then in the Music tab choose Sync music and Selected playlists. Then select the appropriate playlist for each iPod so that they all get their own tunes. Make sure all the songs in music have a tick next to them.
2) Dunno.
I use currently Radiotastic Pro to record radio shows for use on my iPod...
I also have RadioLover which might be exactly want your after, to allow scheduling of recordings. Not exaclty sure why ive got both installed though... :confused:
