Multiple Lian-Li Strimers ?
19 Feb 2007
Northampton
So I just bought myself the 2 x 8pin and 1 x 24 pin Lian Li Strimer for some more RGB goodness but was wondering, Can all 3 be hooked up to the same PCI bracket that has the little buttons on it ?
I was about to ask the same question, I just installed an ATX Strimer cable with the case mounted driver/controller card. Do I have to run a second controller card if I want to fit the 8pin pci-e strimer cable too?
