Multiple monitor question
26 Feb 2004
Hampshire, England.
Hi guys,
A friend has just bought a MSI A320M-A Pro MAX based system with a 3400G. The board has a DVI and HDMI outputs. Will she be able to use two monitors? I think she has 1x monitor with DVI and 1x VGA - guessing she'll need an adaptor for that...
Thanks.
Two monitors yes
Those specific monitors, no. Both sockets are digital and you can't convert digital to analogue (VGA)
Two monitors yes
Thanks! I was sure you could get DVI to VGA adaptors? I remember at work once we had a load of new builds that only have DVI ports on them, and our massive monitors were all VGA - someone just sent the Saturday boy down the road and he came back with a load of adaptors :p Sure it was DVI to VGA...
One of these?
That board only has DVI-D, not DVI-I which would also provide an analogue VGA signal with a simple adapter.
Search for a DVI-D to VGA active adapter and you should be okay (for basic resolutions and refresh rates).
