Multiple monitor setup help (nVidia)
18 Sep 2003
Radlett
I'm not sure if this belongs here or in Graphics Cards, so apologies if I got it wrong.
I'm now the proud new owner of a 3007wfp, and I've been trying to get the following setup working with my 7800GT:
3007wfp | 2001fp Rotated 90˚
2560x1600 | 1200x1600
Unfortunately I can't work out how to rotate only one monitor on a dual-monitor setup, and I can't even figure out how to do horizontal spanning with varying vertical resolutions as a stopgap. I know this is easy with the ATI control centre, so surely this is possible with my card?
Go to the NVidia control panel and find 'Change display configuration'. The option you want is Dualview. If it's not there try rebooting the PC. I had a similar problem when I added a second monitor to my 7600GT - it was picked up by the card & XP but Dualview wasn't there until I rebooted.
