Multiple monitor software on W10
Pij
Pij
6 Feb 2003
Norfolk
I've got a PC with a monitor and TV wired up to it, Is there any software that for example runs in the tray, so I can switch exclusively between monitor 1 or 2, instead of going into display settings then choosing "show only on X"
Thanks in advance!
win+P on your keyboard, its part of windows....
I dont really use windows other than games, All my work time is spent in Linux.
If you want a bit more control or to create your own profiles, there is MultiMonitorTool. I've posted about it before, so rather than copy and pasting I'll just link to the thread.
This is great thanks, as my TV and monitor are different refresh rates, it allows me to set up profiles, which is perfect.
