Hey Guys
I’m worried there may be an issue with my 4090 I purchased from Overclockers. So I’m wondering if anyone has a solution or is this common problem with Nvidia on multiple monitor setups.
Issue
When the GPU is stressed on certain games the HDMI connected monitor disconnects & reconnects constantly.
When I tried the Early access Diablo 4, whenever I had a busy screen, the HDMI started to disconnect & reconnect . I had Aida64 running at the time and could see the 4090 with a 374w power draw 100% usage when running the game on max settings at 3440x1440p 175hz.
At the time I had 2 monitors on displayport and Aida64 monitor panel on the HDMI port.
Recently I started playing The last of us and the same thing started happening again…
Resolutions attempted to address issue
Displayport 1 - Alienware AW3423DW 3440x1440p 175hz
Displayport 2 - Dell S2721DGFA 2560x1440 165hz
Displayport 3 - Dell S2721DGFA 2560x1440 165hz
HDMI - Generic panel for AIDA64 1920x1080p 60hz.
PC Specs
CPU: AMD Ryzen 9 5950X
Motherboard: MSI MEG X570 ACE
RAM: Corsair Vengeance RGB Pro DDR4 3600Mhz 128Gb
M.2 1: WD Sn850x 4Tb
M.2 2: WD Sn850x 4Tb
M.2 3: WD Sn850 2Tb
PSU : Corsair RM1000x 80 PLUS Gold (latest model) connected via APC UPS
12VHPWR : Corsair Premium 600W PCIe 5.0 / Gen 5 12VHPWR PSU Cable
Case : Corsair 5000X
Fans: 10 x Corsair iCUE QL120 RGB
Typical Power & Temps on max load (nothing is overclocked)
GPU : 4090 @ 374w 60-62c (hotspot +10c) (msi afterburner)
CPU: 5950x @ 88w 80-84c (game profile ryzen master)
M.2s (all) : max 60c
North bridge : 69c
System : 48c
Power Draw from mains is 680-700w when running everything (sound,4 monitors 100% usage on both GPU/CPU, transferring large files on network & between m.2s.)
Issue
- Changed HDMI & power cables
- Reseated GPU & cables
- Changed 12VHPWR power cable
- Reinstalled Windows 10
- Updated all firmware on everything and have latest drivers
- Replaced Aida64 panel
- Purchased a Displayport to hdmi adapter and had no disconnects on Aida panel.
- Bought another Dell S2721DGFA 2560x1440 and connected via HDMI and same thing happened in The Last of us (opening scenes)
- Updated again to latest drivers, I haven’t tried windows 11 yet
PC Specs
M.2 3: WD Sn850 2Tb
North bridge : 69c
System : 48c
