Multiple monitors with onboard and dedicated card
17 Mar 2011
Spain
Have a little problem and hoping that someone can help me out with a multiple monitor issue.
Have a computer with an ATI card with a DVI and VGA output. This is working fine to send the display to two monitors but is it possible to activate the onboard graphics to enable a third monitor? I have done a bit of searching and some say it is and some say it isnt and there have been a few guides about enabling the order of the graphics in the BIOS ie onboard 1st but have had no luck
The mainboard is an Asus P5G41T-M LE and was going to add another card but it only has one PCI Express slot so thats a no go.
I think the dedicated graphics card also has a HDMI slot (not with the pc at moment to confirm) so if it does could we even connect the third display with a HDMI to VGA adaptor? Quality is not important as it is only to display on a projector screen so not looking for HD quality or anything.
Cheers
