Well, for pretty much the last several years I've always required two network connections, one to the internet via virgin hub and one to my LAN network for gaming and file transfer.
I usually had to unplug one network though to use the other, but since I got a P5Q-E I have multiple ethernet ports on the motherboard.
One of the ethernet ports goes to my TP-Link router then to the internet [LAN1], the other goes to my switch and to my server - no Internet [LAN2]
Whenever I have them both active at the same time however, everything tries to connect to the internet through LAN2 and not LAN1 where the internet connection is...
How do I fix this? Has it anything to do with the default gateway, I tried Googling but it seems gibberish to me, I'm no network guru.
Anybody have any knowledge/ experience? Thanks in advance.
