multiple pc's ???
6 Jan 2006
Newcastle
hi, ive had a quick glance at the guide but i dont think it answered this i have about 4 computers now at my disposal so if i all hook them up with some interrrnet connections would i just use my user name and login and then let folding run its course and would that work etc ???
You simply set up each PC with the same user ID (which needs to be unique to you) and same Team Number (10, of course!) and your score will be the accumulation of all the WUs done by the PCs.
Hope that helps.
ms9cw
