Multiple RDS servers and hundreds of ThinWin clients
5 Oct 2004
Notts
I've been brought in part way through a project after the guy running it went off sick with stress and could do with some help!
There are five RDS servers all looking after different applications and a couple of hundred PC's running ThinWin clients. Roughly 40 PC's will need to access each RDS server and only the one with the relevant apps installed.
What do I need to do to make sure the PC's only connect to the chosen RDS server and not stray onto another?
As far as I'm aware the RDS servers are all working individually and are not setup for load balancing etc.
Any info would be great :)
I'ld probably looking at deploying a connection broker on say three servers, see how it works and then after that is successful then deploy to the other two.
If you're not sure of the setup then it could lead to problems later. How are they connecting at the moment? IP address, A Name (DNS Record)? Are some of the clients connecting to different servers by DNS lookup to unique entries or are there multiple servers with different IP addresses answering on the same CNAME?
i.e.
CLIENT A (fixed in config file)> SERVER A
CLIENT B (fixed in config file)> SERVER B
-OR-
CLIENT A > RDSTERM (CName) > (DNS Randomly assigned) > SERVER A (or B)
CLIENT B > RDSTERM (CName) > (DNS Randomly assigned) > SERVER B (or A)
I've seen it done both ways before can be a bit of a nightmare in either case when something goes wrong, advise caution. :)
Thanks for the help guys. I'm visiting the site tomorrow so will gather more information on the setup and report back. I think it's going to be messy!
