Multiple S23A700Ds and Eyefinity 3D
6 Jan 2007
Evening,
Has anyone been able to get two (or more) S23A700Ds to work in Eyefinity 3D?
I recently bought two of the Samsung monitors from OcUK and a Club 3D miniDP to active DVI dual link adapter. I have connected one monitor directly to the DVI-D output on my Radeon HD 6950 and the other to one of the miniDP outputs via the adapter. Unfortunately, whilst both monitors work at 120Hz in 2D, only the DVI-D monitor will actually generate a 3D image.
I know others have battled with this in the past but I wondered if anyone had actually had any success.
I am not sure if it is just an issue with the Club 3D adapter (which explicitly states it is for stereo 3D gaming). Has anyone tried using one of the Startech active adapters for Tridef/HD3D with one of these monitors?
Many thanks.
Ive read about a lot of people having this or similar eyefinity issues, so you are not alone. Sadly i have no experience with it myself yet besides from a simple 2 screen setup for 2d desktoping so i cant help you.. Hopefolly someone in here will know what to do.
My understanding with HD3D is if you want to do 120Hz 3D on 3 monitors then they all have to be connected via HDMI 1.4a connections. Currently there's no way to do this.
I got 3 screen, Eyefinity working using Tridef with 3 LG passive 3D screens. That's a bit easier to achieve as you don't need the quad buffer as it uses alternate line 3D.
