21 Sep 2008 at 16:39 #1 quackers quackers Soldato Joined 18 Oct 2002 Posts 5,832 Location Liverpool :-) Is there any software out there that will combine a number of vob (all part of the same film) files to one avi?
21 Sep 2008 at 17:17 #2 bledd bledd Don Joined 21 Oct 2002 Posts 46,859 Location Parts Unknown autogk you can rip them to one vob file using dvd decrypter, ifo mode (ifo options, turn off splitting)
21 Sep 2008 at 17:51 #3 quackers quackers Soldato OP Joined 18 Oct 2002 Posts 5,832 Location Liverpool :-) ah that's an idea, cheers bledd.
23 Sep 2008 at 19:11 #4 quackers quackers Soldato OP Joined 18 Oct 2002 Posts 5,832 Location Liverpool :-) Another thing, is there any software that will take vob files and convert to mpeg4?
23 Sep 2008 at 20:30 #5 Rainmaker Rainmaker Soldato Joined 18 Aug 2007 Posts 9,971 Location Liverpool WinAVI, but it isn't free...
23 Sep 2008 at 20:49 #6 helmutcheese helmutcheese Permabanned Joined 19 Jun 2007 Posts 10,717 Location InURmama Virtualdub Modded or Virtualdub+MPEG2 Plugin. Make into whatever you want if you have a Codec installed.
23 Sep 2008 at 21:12 #7 jbloggs jbloggs Soldato Joined 4 Sep 2005 Posts 6,803 Location UK Format Factory SUPER
23 Sep 2008 at 21:40 #8 quackers quackers Soldato OP Joined 18 Oct 2002 Posts 5,832 Location Liverpool :-) Format Factory looks awesome, downloading now. I'll report back with mpeg4 findings
