Multisync 20WGX2
16 Jul 2005
Hi..
My NEC Multisync 20WGX2 monitor has been working fine ever since I bought it from OcUK, but recently, just over the last couple of days, the screen has started flickering blue from time to time. It's not a constant thing, and it doesn't seem to follow any pattern, it'll just flicker a blue colour. It doesn't go completely blue, it just makes everything on the screen more blue for a moment before going back to normal.
This is slightly worrying, so if anyone has an explanation or if you have any specific questions to ask, please say.
Thanks.
KillerCars
Hi.
Well, I previously had my Samsung 19" monitor for a long time and never experienced this problem so i'm pretty confident it's to do with the monitor. My setup has not changed at all between having each monitor.
alright, i checked and it isn't the graphics card.
Maybe it's because it's overheating? does anyone else have this monitor and experience this problem?
KC
Hi again...
I turned on the monitor today and also noticed all the text seems very fuzzy. I'm pretty sure it's not my eyes.. they seem to be working ok... I've fiddled with the options, sharpness and stuff, and it doesn't seem to help. Do I need this monitor replacing or something?
Thanks. KC
