Mundane pipe question
18 Oct 2002
UK
Dull question, but no more inane than most posts here :p.
Where the hot / cold tubes of a washing machine meet the pipes there is a mechanical switch. Should the water flow if it's in the upright position, or should it flow if it's at 90 degrees, pointing to the right?
If I'm reading your question correctly then the 'on' position of the red/blue lever is definitely horizontal:)
Only on OcUK can such a simple question become so complicated:p
My answer was assuming your pipes are horizontal too meaning that when the lever is inline with them the water should flow:)
