It is very expensive but powder coating a TJ07 and cutting windows if flipping the mobo etc will cost around £450 by the time you put midplate / backpanes perspex top and rad stands in anyway.
The drive bay is outstanding too. I spec'd one with the lightbox mid plate, aquaero bay and rad/pump stand = £900
When you look at the work that has gone into it, its a bargain.. not so much a modded TJ07 as a re-manufactured one. Silverstone are making the chassis for the Murdermod MKII project.
Pulse & Coldzero parts for the TJ07 are great but the murdermod bits are a step up... an example being the motherboard tray.. 8mm thick plastic from Coldzero.. 8mm thick Aluminium from murdermod....& Pulse.. they don't make one, although if you ask Tom nicely I'm sure he would make you one to what ever spec you wanted
If you don't have the time to spend on making a TJ07 how you want it this is a winner.
I have thought long & hard about buying one even got permission from her that must be obeyed, but I have a TJ07 project already on the go & I'm not sure if would be happy modifying the Murderbox further.. its so beautiful! .. I'm still thinking about it lol
