Mushkin 2GB DDR XP4000 Extreme Performance timings??
19 Oct 2002
Yeovil
Recently upgraded fom 1gig of corsair xms3200 upto 2gig of this mushkinxp4000..on my asus a8n-sli premium..what timings would i be best to run...bit confused with all the timings in the bios tbh..cpu im using is a 3500 venice
thanks in advance
Q
hi , 3-3-2-8 is default and that is at ddr500 so you have room at stock ram timings to up your fsb and lower your multi , force the command rate to 1t if possible to help performance
I do apologise for my ignorance !! but how do those timings fit in these settings
memclock index value 400mhz
CAS# latency 3
Min RAS# active time 8t
RAS# to CAS# delay 4t
Row precharge time 3t
Rowcycle time 12t
Row refresh cyc time 16t
Read-to-write time 5t
Write recovery time 3t
1t/2t memory timings 2t
Cheers
the ones you want in order are
CAS = on yours ( CAS# latency)
RAS to CAS delay (RAS# to CAS# dleay)
RAS (row Precharge time)
cycle time (Min RAS active Time)
think that is correct best way to check in CPU-Z will tell ya *** is *** then you can work out *** to change.
im currently running 3,3,2,8 in the order above
CAS# latency 3
Rowcycle time 12t
Cheers
