Mushkin & Asrock Dual
6 Nov 2005
Aberdeenshire
Will the Mushkin 2GB DDR XP4000 Extreme Performance Dual Channel Kit (2x1GB) CAS3 (991483) (MY-000-MK) that's on this week only work fine in my Asrock Dual board?
Anyone have any experience with that combo?
I'm looking for a 2GB kit that can copy with high FSB's and still have half decent timings.
Yep will run fine m8,i had Mushkin 2GB DDR XP4000 Redline Extreme running in my asrock.
No problem and i think you will be very happy with your choice,my ram overclocks like a good un :)
You lot are lucky, im stuck with DDR2 slots..:( I want mushkin to make DDR2 ram...would be so much fun!
Patriot are okay, but it seems very costly..
clone said:
Muskin do make DDR2 ram m8 google :D looking at getting some with my new build.
Ohhhh! I only thought they did DDR...heh! That's me taking for granted OcUK's stock list! I will definately now google it! Thanks for that info clone :)
Change of plan....
I was going to buy the Mushkin black ram when it was on offer but after much reading up i've discovered that the general opinion (on other forums) is that Crucial's Ballistix Tracer memory is the best DDR ram money can buy.
I've seen people have 310MHz out of them at 3.1v with 3-3-3-8 1T timings.
And they are cheaper than Mushkin's redline stuff... only £170inc
Think i'll order them instead.
All in agreement?
realscot said:
Change of plan....
All in agreement?
its the best but doesn't last too long if you feed them with more than 2.8v ;)
