Music Bee Stops Chrome from Outputting Sound
17 Jun 2012
South Wales
Hi all
I have recently switched to Musicbee from Win Amp and found a strange problem. When Musicbee is open Chrome does not output any sound, it's not anything else because if I close Musicbee then it works fine. I think it must be something to do with me changing the Audio Output of Musicbee to WASPI, however I can't change it to anything else as the other options either don't work or sound awful. Any help would be much appreciated as I'm pretty confused.
P.S Are there any skins/plugins that you would recommend?
WASAPI takes exclusive control of the sound device so you don't want that. if there is a direct sound option, you should use that. it should not sound any different. if it does, the player is broken.
Thanks for the help, the direct sound option didn't work as the 32 Bit output option was ticked. My sound card was on 32 bit output but for some reason it didn't work, I unticked the option and it now works.
