Music production and gaming build £1000
12 Nov 2014
Bristol, United Kingdom
Hi all
Following the great success of the 500 build I did on here I'd like some more help!
I'm building a rig for music production, and also gaming (FPS etc, so decent performance needed). I also need to be able to run Ableton live as smoothly as possible. Dual monitor support would be awesome too.
Need a copy of windows 10 so that'll be in the 1000. Don't need any peripherals at the moment.
Is it possible to future proof this for 4k?
Thank you in advance!
Something like this? I'm not sure whether you would prefer a better CPU or GPU but this is using the i5 with a 1070, you could swap to an i7 and something like a 1060 3gb for a little bit cheaper.
My basket at Overclockers UK:
  • 1 x OcUK Kinetic Z1 - Intel Z170 Configurable Skylake DDR4 Gaming PC = £1,076.88
    • Case:Kolink Victory ATX Midi Tower Gaming Case - Black
    • Processor:Intel Core i5-6600 3.30GHz (Skylake) Socket LGA1151 Processor - Retail
    • Memory:Team Group Elite 16GB (2x8GB) DDR4 PC4-19200C16 2400MHz Dual Channel Kit - Black (TPKD416GM2400HC16D
    • Storage Mechanical Hard Drive:Seagate 1TB 7200RPM SATA 6Gb/s 64MB Cache HDD - OEM (ST1000DM003)
    • Optical Drive:Unwanted
    • Operating System:Microsoft Windows 10 64-Bit DVD - OEM (MS-KW9-00139)
    • CPU Cooler:Alpenföhn Sella CPU-Kühler, SI - bulk CPAF-027
    • Build Time:Standard Build Systems - Dispatched within 7 working days
    • Warranty:OcUK Standard System Warranty - 3 Year (24 Month C&R + 12 Month Labour)
    • WIFI:Unwanted
    • Primary Solid State Drive / Hard Drive:Samsung 250GB 750 EVO SSD 2.5" SATA 6Gbps Solid State Drive
    • Security Software:Unwanted
    • Graphics Card:KFA2 GeForce GTX 1070 "Reference Blower" 8192MB GDDR5 PCI-Express Graphics Card (70NSH6DHK6VK)
Total: £1,090.98
(includes shipping: £14.10)
For the storage by default I tend to put a 250gb SSD and a 1TB HDD as that's my personal setup, you could just go for a 500gb SSD but obviously it depends on how much space you'll need.
I would say it'd decent for the price, if you did want to build it yourself it may be slightly cheaper but then you wouldn't get our system warranty and we QC the system before it leaves to make sure there's no faults at all.
i7 + 1060 - If more music production
i5 + 1070 - If used more for gaming
Exactly, it is a little bit cheaper going for the i7 and the 1060 but it's completely up to you which takes priority.
