penski said:Not on my car...on a mates' mk2 carlton estate.
comedy levels of poke. we couldn't even take it down off the jack because the arches dug straight into the tyre.
10" wide wheels with 265 section rubber...
*n
Burned_Alive said:So you fitted wheels that you knew didnt fit and then took them off?
Are they going back on after modifications or....?
Burned_Alive said:Ah, i just presumed from the picture it would be obvious by looking at them that they wouldnt fit.
penski said:Unfortunately you never know with these things until you try...
*n
AcidHell2 said:whats the point, with out extending the arches you would get stopped by every cop and fail the mot.
