MW3 Eyefinity help??
20 Jun 2009
UK
Hi im trying to play MW3 Via Steam with the widescreen fixer app, i had no probs in the past with MW2 but now i have MW3 running at 7680 x 1440 i can't find away to reduce the image size. Thanks
Widescreen fixer works fine in mw3 for me at 5960x1080, make sure your using the newest version and make sure the profile in widescreenfixer matches the current version of mw3 your running.
Hi, yeah latest verion and same for widescreen fixer, when i press the buttons i have set to activate the fix its works but everything looks over size still :s
Strange, works fine for me also at 7680x1440. Only problem I had was when the versions didn't match.
