MX-3 v MX-4
27 Jun 2005
Reading
Hi guys just a quick one.
Finally found my tube of MX-3(currently using AS5). Is it worth buying MX-4, is there any real difference?
Not particularly. Not performance wise any way. MX-4 is easier to work with which I believe is the reason they got rid of MX-3 so quickly.
yeah should drop temps by 3-4c?
Comparing to AS5? I doubt it would make much noticable difference (if any).
Majority of people (myself included) prefer the MX is because they are non-conductive (unlike the AS5) thus safer to work with. But if you already have AS5 on your current chip without problem, I see no reason to replace it with the MX.
