just wondering how you check if the mouse is actually charging or not?
i've plugged the base into my pc via usb, installed the SetPoint software from the Logitech site.
i've pressed reset on the base, and then on the mouse
when i put the mouse into the base, are the LEDs supposed to flash or anything?
it just sits there, and then the LEDs go out after a while (like when it doesn't move).
also i didn't get the AC adapter with the mouse, was i supposed to...?
got it from OcUK - it arrived today
cheers
edit:
excuse my foolishness - just found the AC adapter i had it in a pile which i thought had come with my new case (which needs to be sent back)
cheers
edit:
