MX518 replacement
3 Jan 2003
looking to replace my old MX518, was thinking Naos 7000.
The Naos 7000 does look big, even compared to the MX518! which isn't the smallest mouse..
tried to find somewhere with the 7000 on display so that I could use it, but nothing local. Anyone that has used both give me a quick comparison?
cheers
Logitech G400 is a direct port of the MX518, that's if you don't want to try anything new. I haven't used the Naos 7000 so I couldn't tell you.
