Hey guys I'm upgrading my pc with a max of £2000. Last time I upgraded was when the 7800GTX was the card to have, so maybe a year ago was my last full upgrade.
My current spec:
PC Case: Lain - Li
Power Supply: Noisetaker 600W
Processor: Dual Core 4800+ @ 2.7Ghz
Memory: Corsair 2GB DDR XMS3200C2PT TwinX
Motherboard: DFI Lan Party SLI
Graphics: GeForce 7900 GTX 512MB
Harddrive: WD Raptor 74 GB 10,000rpm
Monitor: BenQ FP241W 24
Resolution: 1920x1200
My current OcUK Basket:
EVGA nForce 680 (Socket 775) PCI-Express DDR2 Motherboard
2x BFG GeForce 8800 GTX 768MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail
Enermax Galaxy 1000W EGA1000EWL ATX2.2 Modular PSU
Team Xtreem 2GB (2 x 1GB) DDR2 PC2-6400C4 800MHz Dual Channel Kit (TXDD2048M800HC4DC)
Intel Core 2 Quadro Extreme Edition QX6700 "LGA775 Kentsfield" 2.66GHz (1066FSB) - Retail
Total : £2,073.75
I'm sorted with the Motherboard, Graphics, CPU. I'm not to sure on the Memory and the PSU.
So what is your suggestion when it comes to the PSU + Mem? I will be overclocking this baby, also maybe add Windows Vista to the basket? Plus is there anything around the corner which would stop you ordering right now? As I can wait a few weeks if needed. Are there any none bugs with this mobo which mite need a bios update?
Cheers
p.s this upgrade is in need for ET:QW
My current spec:
PC Case: Lain - Li
Total : £2,073.75
Cheers
