2 Apr 2006 at 16:54 #1 AlanJ AlanJ Associate Joined 16 Nov 2005 Posts 683 Location Torquay Hiya finally overlocked my chip What do you think? I might try for more! The stepping is Kab2e not sure of the rest. click here
2 Apr 2006 at 19:07 #2 ajgoodfellow ajgoodfellow Soldato Joined 24 Dec 2004 Posts 11,373 Location Knowle, Solihull, UK KAB2E is a great stepping 2.8Ghz stable on stock volts is a great start too. You just know you want to try to push it to 3GHz!
2 Apr 2006 at 19:12 #3 bbreezeuk bbreezeuk Permabanned Joined 21 Nov 2005 Posts 1,140 Location Bath, UK will KAB3E achive 3ghz with my mobo
2 Apr 2006 at 19:22 #4 AlanJ AlanJ Associate OP Joined 16 Nov 2005 Posts 683 Location Torquay Yeh, im going to try for more, although my temp readings are a little strange, they keep jumping around. Whats the max voltage on these chips? 3ghz here i come!
2 Apr 2006 at 20:28 #5 kdd kdd Soldato Joined 29 Oct 2005 Posts 3,822 Location Kent At stock volts that is superb! Go to 1.55 max but you should get to 3gig on about 1.45 no doubt.
2 Apr 2006 at 20:30 #6 ajgoodfellow ajgoodfellow Soldato Joined 24 Dec 2004 Posts 11,373 Location Knowle, Solihull, UK bbreezeuk said: will KAB3E achive 3ghz with my mobo Click to expand... It should - it's a good stepping and you've got a good motherboard
2 Apr 2006 at 20:33 #7 AlanJ AlanJ Associate OP Joined 16 Nov 2005 Posts 683 Location Torquay Im @ 2890 still at stock volts! Will leave prime running.
3 Apr 2006 at 00:59 #8 AlanJ AlanJ Associate OP Joined 16 Nov 2005 Posts 683 Location Torquay WAHOOO! 3042ghz, take a look clickme
3 Apr 2006 at 01:01 #9 ajgoodfellow ajgoodfellow Soldato Joined 24 Dec 2004 Posts 11,373 Location Knowle, Solihull, UK Sweet!
3 Apr 2006 at 15:15 #10 Dreadi Dreadi Soldato Joined 16 Feb 2006 Posts 7,665 keep going!! what temps you getting ??
3 Apr 2006 at 19:33 #11 AlanJ AlanJ Associate OP Joined 16 Nov 2005 Posts 683 Location Torquay temps are around 39 idle 48 load on air cooling, primes been running for 6hours now all seems good.
