- 6 Oct 2005
Well after a bit of thinking I've decided it's better to go the 'whole hog' rather than just do an upgrade, cos prices seem to have fallen quite a bit in the last couple of months.
So here's my intended spec:
OcUK GeForce 8800 GTS 320MB GDDR3 HDTV/Dual DVI (PCI-Express) - Retail (£170.36)
Intel Core 2 Duo E4300 "LGA775 Allendale" 1.80GHz (800FSB) - Retail (£77.54)
Gigabyte GA_965P_DS3 (Socket 775) PCI-Express DDR2 Motherboard - OEM (£58.75)
Hitachi Deskstar T7K500 NCQ 250GB SATA-II 8MB Cache - OEM X 2 (£86.92)
Arctic Cooling Freezer 7 Pro CPU Cooler (Socket 775) (£18.79)
LiteON DH-18A1P-018C 18x DVD±RW x12 Ram Dual Layer DVD-Writer - OEM (£17.61)
Microsoft Windows Vista Home Premium 64-Bit Edition DVD - OEM - 1Pk (66I-00788) (£75.19)
OCZ 4GB (2 x 2GB) PC2-5400C5 Dual Channel Vista Upgrade Gold Series DDR2 (OCZ2VU6674GK) (£146.86)
Antec NSK6500 Super Midi Tower Case - 430W PSU (£69.31)
Obviously I'm intending to overclock the be-jesus out of the E4300, hopefully that ram will overclock sufficiently?
I'll be setting the two HD's into RAID 0 - can I run this mobo off a USB Key or do I need a floppy drive for the RAID setup?
And... I've read the reviews that say 4gb is deffo worth it for Vista, and if only 3gb is addressable by 32bit, then that seems like a waste of money not to go for 64bit.... right? But will I be ok with the driver situation on 64bit? My peripherals are:
Speedtouch 586 wifi modem/router (no driver req)
Canon MP150 Pixma printer
Logitech G15 keyboard
Logitech MX518 mouse
I'm also aware that the 430w is a bit tight for power, but as it's Antec it should be good enough...?
I just realised in typing this message - the mobo is 'oem' - what bits and pieces do I need to source myself that are normally included?
All in all I think I've come up with a spec that provides a lot of oomph for not much dosh - is there anything else I can improve?
All thoughts gratefully received
