Akasa 965...great cooler - similar to the arctic cooling freezer pro 7 in design. i brought as it is pretty cheap and fitted on my mobo fine.
thanks man
Been reading about this cooler dude, I'm gonna say you have your fan on upside down? should overhang at the bottom not the top, but perhaps it;s sits to close to the ram or something hence your 'mod'
Can I be a real bore now and ask you the height of it? Review sites are all quoting different numbers at me and would love to know basically how high the top sits from the mobo, right to the heatpipes, power down the PC before measuring!!! -or use a plastc rulethanks man
ill get the measure meants today for you when i have time. and yeah the fan/cooler frame is upside down. its because it was touching my ram (probably because of the matx layout) and i wasnt really happy with that but upside down it left a bit of room in between the too. didnt change temps or anything at all.
Cool, I read that it's to help cool the mobo down, mosfets/caps and all that junk, but if your machine is stable and running good then I don;t see it being a problem, the big meaty exhaust fan helps too I'd guess![]()
