My Antec P50 mATX Dual Chamber Windowed Cube Case - Build (21-08-2015)
That's a job well done. How is the air flow the case and temperatures?
Hello faheemrazzaq , Well the Sentry 3 Control great for managing all 5 case fans on "Performance mode" pushing a lot of worm air out back of case & top ,Air flow is Great like other Dual Chamber cases in this design like the
"Corsair Carbide Series Air 240" theres even 2 - 80mm fans slots Front & back behind the motherboard tray if needed,
I purchased the "Noctua NH-U9S PU Cooler - 92mm" being under 130mm hight for the case , Playing skyrim the temps are in the 60s touch70c on 1 of the cores on the i7 4790k at stock speed,
not over the moon on the CPU temps but the Noctua fan Is dead silent even on full load & as stated in the review "considered mainstream cooling, fairly good for a kit with a small footprint, I mean these are intended as ITX coolers at a 95x95mm design, keep that in mind. " Guru3d
The review of the Noctua NH-U9S PU Cooler http://www.guru3d.com/articles_pages/noctua_nh_d9l_and_nh_u9s_cpu_cooler_review,8.html
Noise Levels of this cooler is first place beating all others http://www.guru3d.com/articles_pages/noctua_nh_d9l_and_nh_u9s_cpu_cooler_review,10.html
