MY ASUS D2 DOSENT SEEM POWERFUL ENOUGH TO POWER MY DT770 250OHM
1 Mar 2010
castlemilk,glasgow
HI I JST BOUGHT DTT770 250 OHM AND I FEEL THE VOLUME ISINT ASLOUD AS I THOUGHT IT WOULD BE,HAVE I MADE A MISTAKE PAIRING THIS D2 AND THE DT770 250 0HM,BECAUSE IVE SINCE HEARD THE AMP ON THE D2 ISNT VERY GOOD TO DRIVE HIGH INDEPENDANCE HEADPHONE IS THIS TRUE?,I CONNECTED MY FILO E11 INTO THE FRONT PORT ON THE D2 THEN CONNECTED THE DT770 TO THE FILO E11 THE VOLUME SOUNDS MUCH BETTER BUT IVE READ U LOSE SOUND QUALITY THIS WAY IS THAT CORRECT?
** Please refrain from using caps like this.. It can be perceived as being aggressive **
I'm not aware the D2 has a heaphone amp maybe that's why they sound low. So you would need something like the Fiio E11 to drive them. And no you wont lose SQ using a amp.
i thought the d2 must have a amp as it supports dolby headphones,does anyone hnow for sure if the d2 has a amp
Spelling and grammar, is also nice. ;)
The D2 doesn't have a dedicated headphone amp. The Xonar's that do, are the DG, Essence and Xense.
As others have said, using an amp won't degrade the sound quality at all.
it was a typo mistake not a spelling one,im still getting used to my mechanical keyboard,take ur smart alex joke elsewhere im asking for help not cheek ok
To be quite blunt, you already have the amp connected and in use. Why are you asking us if you lose SQ? you should be telling us your findings.
