Thanks to OUK and its forum I have purchased:
I7 D0 920
Gigabyte X85A - UD3R Motherboard
Antec True Power 750W
Noctua NH-D14
2 Samsung F1 500GB
1 Sata DVD RW
HIS 5850
Coomermaster 690 2
2 Fractal Fans - One installed the other still boxed.
Artic Silver 5 Paste
6GB OCZ memory
Few thoughts:
Case:
Awesome case. Seems to be various spacious and teh cable management system does work. However, the cables behind the back panel will look ugly, but that's irrelevant as it wont interfere with air flow and not be seen.
Does have some unnecessary things like external sata and I've taken those cables out.
Noctua Fan:
Computer I am using is a AMD 3500 with artic Freezer. I've had this for five years and I think this fan is huge...until I saw the box and started to un box the Noctua beast. This thing is massive!!!
Does cause a couple of problems with regards to cable placement, but perseverance and can be sorted.
Motherboard:
Read many articles stating that Marvel connectors are rubbish for raid, so I have attached them to the ICHR10R. Otherwise looks very hi tech, and very impressive.
PSU:
Quite disappointed in this. It's partially modular and all the cables I need are fully attached to the PSU. Maybe my fault for not fully exploring this PSU before purchase, but I am sure it's quality and with the Coolermaster case teh cables can be hidden more or less.
Advice Needed:
Okay I do have few queries:
UD3R Motherboard:
1) The manual states that it has a NB Fan connector for the Northh Bridge, I see no fan on the Northbridge, so is this the socket for a fan placed on the side of the chassis?
2)Is the below okay to do?
a) One Noctua Fan to the CPU socket
b) Other Noctual Fan to the PWR socket
c)Used a Y cable to attach the two fans on top of the Coolermaster (one stock fan and ohter is a Fractal fan) to one socket on the motherboard.
d)I have attached two other fans to the other two sockets on the motherboard.
3) Fractal Fans have come with rubber mounts, how do these work?? I've just used screws to screw it in.
4) I have a rear fan, two top fans and one front fan. I've only added the fractal fan at the top so that I have two to get heat out of the system. I have another Fractal 120MM fan and wondered where that could go in the case. Either on the bottom to pull air into the case or on the side to expel or bring air into the case.
5) I have a fan infront of two hard drives, at the front of the case bringing air into the case.. Wont that end up blowing warm air into the case if HD's get hot?
Thanks for any assistance.
I7 D0 920
Noctua NH-D14
2 Samsung F1 500GB
1 Sata DVD RW
HIS 5850
Coomermaster 690 2
6GB OCZ memory
Few thoughts:
Case:
Noctua Fan:
Motherboard:
PSU:
Advice Needed:
UD3R Motherboard:
