- 19 Aug 2011
Hey
I've just ordered this beast, do you think it will last a few years? The intention was to be able to skip the next gen consoles as I couldn't afford a top spec PC the last gen (Seriously I've been playing Stalker, portal 2 etc etc quite well at 720p and high settings with a madly overclocked 8500GT from 433mhz to 720mhz and shader from 720 to 1440 for the past 4 years, such an epic, under rated card for OC)
So do you think it will last about 3-4 years without any significant upgrade? When I say last, I'm quite happy to play games on medium settings in the latter stage.
See Below (Don't need HD, Monitor or disk drive)
Cheers
Cheers
Asus GeForce GTX 580 Matrix Platinum 1536MB GDDR5 PCI-Express Graphics Card
Krypton Z68 620i Intel Core i7 2600K 3.40Ghz @ 4.40GHz Overclocked Bundle
Chosen Option
Kingston HyperX Genesis Grey 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9D3X2K2/8GX)
Chosen Option
Gigabyte Z68AP-D3 Intel Z68 (Socket 1155) DDR3 Motherboard
Microsoft Windows 7 Ultimate SP1 64-Bit - OEM (GLC-01844)
Corsair Graphite 600T Midi Tower Case - Black
Corsair Enthusiast Series TX 850W V2 High Performance '80 Plus Bronze' Power Supply (CMPSU-850TXV2UK)
