My Build... what to upgrade next?
21 May 2017
Rotherham
Hi!
I've recently build by PC (I have some experience in it, so everything is working fine), but I'm thinking about upgrade. What should I upgrade first? Which is the slowest/least efficient part in my PC? How do you think? I'm actually thinking about going into 4k gaming but i'm not sure is my PC good enough.
About my PC:
CPU: i7-7700
CPU Cooler: Cryorig H7
RAM: HyperX Fury Black 2400mHz 2x8GB
Motherboard: Gigabyte Z170XP-SLI
GPU: EVGA GeForce 1060 SC 6GB
SSD: WD Blue SSD 250GB
HDD: WD Blue HDD 2TB
PSU: ******** Black Edition 1000W
Main Screen: BenQ RL2755HM
Secondary Screen: Acer K272HL
Mouse: Corsair Sabre RGB
Keyboard: Zalman ZM-K400G
https://drive.google.com/open?id=0BwvpM-Sf72Q2V1pwS2R1U0IxS2M
https://drive.google.com/open?id=0BwvpM-Sf72Q2RjNrUlhtTzJ2SFU
https://drive.google.com/open?id=0BwvpM-Sf72Q2MXJpME55LWNxZWc
https://drive.google.com/open?id=0BwvpM-Sf72Q2RGJVMG5Ia0dTdnM
https://drive.google.com/open?id=0BwvpM-Sf72Q2eUhXRHVqM0dtVms
https://drive.google.com/open?id=0BwvpM-Sf72Q2TXZWLXB0MVB5Nnc
P.S. Don't mind the mess in my room, that's what you get when you have two cats.
It works fine, but I'm thinking about 4k gaming. So I'm thinking that I need to buy at least 1070. For anyone who noticed, I choose 1000W PSU because I want to go on SLI soon.
I do not have a 4k monitor yet, but before I buy it, I want to make sure that my PC will handle it. And 1080 is pricy, and I think that 2x 1070 is more efficient than 1x1080. Besides, I can buy one 1070 and after I get some coins, buy another.
Why do you say that? Everyone I've ever asked told me, that SLI can boost your card 2.5x.
Doubtful. SLI comes with its own set of problems, heat, game/system support etc.
When it works, it's ok but a single card solution is better, although it already sounds like you've made your mind up?
If you want good performance at 4K, you're going to need a 1080TI or Titan XP. 2x 1070's isn't really going to give you what you want.
Didn't make my mind, I'm always opened for opinions, that's why I've asked. I need to dig deeper to see some benchmarks or something to actually see what's better for me.
A 1070 will play games ok at 4k, but be prepared to drop the settings a little.
If you want high settings at 4k then a 1080ti is the only way forward.
