My build
17 Sep 2014
Thanks for the advice, i should also say i don't plan on overclocking that much, plus it being smaller makes it easier for the case, as long as temps are kept down i don't mind!
The case will swallow the bigger rad better as you don't have a fan either side.
They fit perfectly in the roof.
You will, but the extra performance from the bigger units surely must be the logical choice?
