Just finished a bit of a case overhaul *grins manically*
Details are as follows:
- PSU now draws air through top of case, and exausts out of back (seperate form rest of PC
- Added another DVD-RW drive and another FDD
- UV-reactive cables!
- removed all the unused drive bays.
- Jammed an 80mm fan onto the side window
- replaced the horrid plastic bottom 1/2 of the front with wire mesh
- installed UV cathode on/off switch on front
- crammed a 120mm fan in between the bezel and chassis with the radiator inside the case behind it.
- Watercooled the lot
PICS:
before:
And after:
Still have to touch up the black paint around the UV light switch.. and my UV cathode broke literally moments before taking these pics, but soon i'll have another and then we'll see!
Also, I'm waiting for my RMA'd Graphics card back from OCUK (grrr) so the Graphics waterblock isn't on anything yet
I've got a tasty BIOS all waiting for the card and everything... Ram sinks galore and the Waterblock should be condusive to a decent overclock
PICS:
before:
And after:
, they leaked like mad when I was testing out the loop, so I took no prosioners and PTFE'd them to death.
