Well, im not exactly sure on the name of it, as it goes by Shinobi something or other, or TrendSonic something or other.
It came with a black side panel with space for an 80mm for air onto the processor/hs and 120mm for the GPU.
1 120mm front, 1 120mm back. Perfect.
Well, i decided i wanted to see the insides of my case, so i bought some perspex and cut it to size =]
not a bad result me thinks. Might change the red fans to something else to keep it more consistant, got plenty of different coloured ones lying around!
taken the blue neon out the top as i think it put too much "white light" into the case... not sure though
Best of all.. it cost me like £35 or something silly! Anyway enough typing.. heres the pics.. prety well built case too tbh.
http://www.fisha.co.uk/case1.jpg
http://www.fisha.co.uk/case2.jpg
		 doesn't look too bad at all!
