my clock is wrong..
5 Jun 2005
Southampton
my clock is wrong or loses the settings when the pc is off, i guess the bat has died?
anyway does anyone use one of those free proggies off the net with a clock that syncs with the internet? i don't wanna download a spy packed one
replace the battery, and redo your bios settings
disable things like COM ports and Parallel ports if you don't use them :)
yeah might be the best bet, it's a shuttle system so i will need to look up the battery part, or are these things all the same?
I use analogX atomic time sync.
pretty sure they all use the same type of batteries, last time i changed one i just went into superdrug and bought a battery that looked the same size, was thinner, but it works fine :)
start --> run --> cmd
type "net time /setsntp:0.uk.pool.ntp.org,1.uk.pool.ntp.org,2.uk.pool.ntp.org" enter
make sure that your clock is reasonably accurate by typing "time" - enter the correct time, "date" - set the correct date.
"net stop w32time" enter
"net start w32time" enter
this will sync your clock with the uk ntp pool.
ntp has problems if the hwclock is way out, so unfortunately, you'll either need to keep your pc powered on all the time, or replace the mobo battery.
