Hey everyone,
I've taken loads of advice over the past few weeks and I want to thank you all for that. Now I've got my final build decide upon and I wanted to see if any of you willing will look it over and point out any compatibility issues you spot or even just any tips from your own experience:
Case - HAF X
http://www.overclockers.co.uk/showproduct.php?prodid=CA-203-CM
HD - 2x Seagate Momentus XT 500gb 1x Corsair Force Series 3 120gb
http://www.overclockers.co.uk/showproduct.php?prodid=HD-233-SE
http://www.overclockers.co.uk/showproduct.php?prodid=HD-021-CS
Motherboard - Asus Sabertooth 990FX
http://www.overclockers.co.uk/showproduct.php?prodid=MB-460-AS
Memory - 2x Corsair Vengeance 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz
http://www.overclockers.co.uk/showproduct.php?prodid=MY-292-CS&groupid=701&catid=8&subcat=1387
Processor - Bulldozer
I will be waiting for one of the new AM3+ processors to be released
Gfx Card - ATI Radeon 5700 series HD
This is my old graphics card that I will be keeping
Know Issues:
I know that I am buying three Hard drives that are all 2.5" and that the HAF X case only has 1 adapter that changes a 3.5" bay into 2.5" however I've contacted Coolermaster and I'm hopefully going to find a way to purchase two more adapters. This will be done before I buy any Hard Drives. I am also putting my old 1tb into the case but that will be used for dumping movies and music files on.
So as I said if you can flag up any obvious blunders I would really appreciate it
Case - HAF X
Know Issues:
