Hi,
might be a basic question but I cant seem to find an answer to it.
In "My Computer" there are choices of fields you can have to show info on the drive(s) etc. There is a "Comments" one but how the heck do you actually add a comment!? Ive right clicked the drive and looked at the properties but nowhere says anything about the comment.
Basically I want to add comments for each partition so I can see which disk they are located on easily without going to the Disk Management snapin each time.
Cheers
Cheers
