Same clock as I currently have, definitely amazing processors.tiber said:must say these conroes are amazing![]()
mine is priming at 3ghz (e6300@430 fsb) at stock volts![]()
temp is 58c under load on a zalman s9500-would a ninja do it better?
My E6300 is currently 32ºc idle and 46ºc at full load under a Ninja.
What's say with coretemp at full load?Úlfhednar said:Same clock as I currently have, definitely amazing processors.My E6300 is currently 32ºc idle and 46ºc at full load under a Ninja.
tiber said:jeese that is cool! gonna get me a ninja.i take it you have the fan fitted?
Nope, I am not using it as it rubs against one of my other fans. I have an 80mm intake on my side window and two 80mm exhausts in the rear so I get plenty of nice airflow through the machine.tiber said:jeese that is cool! gonna get me a ninja.i take it you have the fan fitted?
46ºc at full load when running two instances of SP2004, which is actually a higher temp than when I run the CPU tests in 3D Mark 06.fornowagain said:What's say with coretemp at full load?
Or there's something wrong with your Ninja, or it needs re-seating. When I first put the Ninja on I was getting 70ºc under load with a 2.8GHz OC, I thought that was oddly high so I re-applied my AS5 and reseated it and bam, temps dropped by a good 20+ degrees.sgoaty said:I dont get temps like that with my ninja. They are either not as good as everyone says or the chips put out quite a bit of heat
Sure that not the motherboard cpu sensor, are you checking the "on die" diode core sensors?Úlfhednar said:46ºc at full load when running two instances of SP2004, which is actually a higher temp than when I run the CPU tests in 3D Mark 06.
Temp 1 is the ambient temp sensor, temp 2 is the CPU sensor.fornowagain said:Sure that not the motherboard cpu sensor, are you checking the "on die" diode core sensors?
Úlfhednar said:Temp 1 is the ambient temp sensor, temp 2 is the CPU sensor.
Edit: Just ran Core Temp Beta 0.9.0.91 and got more or less the same result (on both cores), just a couple of degrees higher.
Have a look here , #47. Maybe the readings are a bit off.sgoaty said:Mine has been reseated then i swapped out my CPU for a 6600 that got hot too
im now back to using the E6300 with load temps of around 60C
tiber said:Ill give that a go![]()
tiber said:yep thanx3.2 ghz now.prob is,when do you stop!!
and its still on stock volts.
