my conroe spec plz check
22 Oct 2004
Right im not sure if ive choosen the right stuff but thats all i need as my graphics card and other stuff that ill salvage from my current spec will go into this one.
But anyway plz check to see if i got the right stuff :) :
GeIL 2GB (2x1GB) PC6400C4 800MHz Ultra Low Latency DDR2 Dual Channel Kit (GX22GB6400UDC) £169.99
(£199.74) £169.99
(£199.74)
Creative Sound Blaster X-Fi Fatal1ty FPS Edition - Retail £122.99
(£144.51) £122.99
(£144.51)
Samsung SpinPoint T HD401LJ 400GB SATA-II 16MB Cache - OEM £82.99
(£97.51) £82.99
(£97.51)
Abit AW9D-MAX Intel 975X (Socket 775) PCI-Express DDR2 Motherboard £119.99
(£140.99) £119.99
(£140.99)
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail £191.99
(£225.59) £191.99
(£225.59)
Western Digital Raptor 74GB WD740ADFD 10,000RPM SATA 16MB Cache - OEM £91.99
(£108.09) £91.99
(£108.09)
Sub Total : £779.94
Shipping : £8.95
Vat : £138.06
Total : £926.95
Basically its going to be a gaming rig and there will be no overclocking whatsoever thats why ive chosen some cheaper memory, but should still be good as its GEIL.
And am i right that the motherboard does support crossfire and you dont need to mod it so it does :)
well ive just finished my order and its changed a bit this is what ive ordered:
GeIL 2GB (2x1GB) PC5300 667MHz Value DDR2 Dual Channel Kit (GX22GB5300DC) 1 £129.99 (£152.74)
Western Digital Raptor 74GB WD740ADFD 10,000RPM SATA 16MB Cache - OEM 1 £91.99 (£108.09)
Intel Core 2 DUO E6600 "LGA775 Conroe" 2.40GHz (1066FSB) - Retail 1 £191.99 (£225.59)
Abit AW9D-MAX Intel 975X (Socket 775) PCI-Express DDR2 Motherboard 1 £119.99 (£140.99)
Western Digital Raptor X 150GB WD1500AHFD 10,000RPM SATA 16MB Cache - OEM 1 £140.99 (£165.66)
So i think thats a lot better and with the 74gb hardrive thats for my OS and the other is for my games :)
Looking at my sig below do you think the difference will be big in games that i currently struggle with.
the components in your current sig shouldn't be struggling with anything!!!!! :eek:
How do you mean struggle with current games?
With that gfx card and cpu, nothing should really struggle at all!!
enjoy your new rig but i'm stunned that anything is struggling with a X1900XTX and 4800 x2. :eek: :eek:
Nowt wrong with the Geil Ultra Low Latency pc6400C4 800mhz 2gb kit, using the same Ram here with an E6600 Conroe, and my rigs still at stock, no need to overclock it as its fast enough, spose it will come in handy if i ever do want to overclock, but i can't see it, games are flying anyway. :)
Im afraid even with my current spec some of the newer games aint running amazingly well. But i wont have that worry now with this beast fingers crossed :)
will my psu run all this alright and or do i need a new powersupply:
Enermax Noisetaker 600W
do i have the cheek in asking could it also have crossife running :confused:
bakes0310 said:
{snip}Enermax Noisetaker 600W{snip}
PSU is more than fine, even for CrossFire ;)
TBH don't see how your current rig is struggling? If you compare the X2 4800+ & E6600 (here), its no slouch :D
Think you should have gone CrossFire or even 8800GTX :( On a positive note, resale value of your 'old' components is very good :)
VeNT said:
your blatantly not folding on it.
nah boring :p ;)
ive just installed splintercell double agent to see if it suffers with the terrible slowdown and thank god it doesnt so now ive got 4 main games ive got to play now:
splinter cell double agent
wow
oblivion
medieval 2 total war
Just never enough time :( :)
