- 27 May 2007
- Kent
I bought the Artic cooling Accelero twin turbo made a good job of it on one of my 4870 put back into comp went to fit the crossfire links and the AC Accelero heat pipes stick up so much that the crossfire links rest very tight on them but got so far into project that i went on and booted up comp.
Temps for that card went through the roof it was quite sound wise done some furmark just got too hot, so pulled card back out of computer and those heat pipes were so hot i could not touch and forgot about the crossfire links just cought that in time.
I pulled card apart again then read what sharpygsxr did and fitted the metal red base plate on first then the AC Accelero on checked paste on GPU just to make sure all seemed OK put card back in re test and still to hot though VDDC temps were better so a wast of time....
So i put back stock cooler with new past much louder in noise but feel bit more confident in card, though if i run furmark max temps seem to hit 102 /c
Is that too hot anyone??? also in all this motherboard temps were very hot too NB temps around 70-85 /c CPU around 50 /c and system temps around 50-60/c
In the end bought two Akasa 12cm UltraQuite fans one suck and one blow and all temps have dropped BIG TIME CPU 31 /c NB 59 /c motherboard 40 /c
But maybe i still need to sort out the 4870 temps.
Sorry for long wright up but just in case this helps someone then great.
