- 7 Feb 2010
- Jolly ol Stoke
I cant really call this a project/build log just yet because its already assembled for now lol. That being said i do plan to ditch the Sapphire GPU and get 2 reference model cards and get me some watercooled crossfire goodness very soon!
All freshly re-housed in a coolermaster cosmos ii today which looks fab. I was hoping not to have the dreaded fan controller issues as OCUK told me this has the revised version of the fan controller, but the buzzing/clicking is present when the fans are on med/low speeds. A little dissapointing, but no biggie as i half expected it anyway.
The current spec consists of..
2500k i5
ASUS p8z77 board
sapphire 7970
x2 Samsung ssds (120gb and a 250gb) and a WD 1tb storage drive
8gb of Crucial Ballistix ram
First things first pull off the front panel and trim down the ridic amount of cables coming from the front panel. This photo was taken yesterday however ive since decided to ditch the CM fan control because its utter garbage so that should thin the rats nest of wires down even further.
This is my first build where ive been concious about cable management, for my first attempt i dont think ive done TOO bad, although there is some room for improvement, however ill re-tackle this when i go for a full w/c solution
A shot from the business side! First of all i know the cables need braiding, the yellow/black and multi coloured wires in the GPU and main mobo connectors stick out like a sore thumb! Also the front panel on this case needs its own feed direct from the PSU, sods law has it that its a molex connector on the front panel, the ONLY molex connector in the whole damn rig so that means a whole cable with x4 molex plugs from the PSU to hide! I think im going to look for some sort of sata/molex adaptor or just get a fresh sata connector and crimping tool from MDPC so i can power the front panel from the sata cables currently powering my hard drives
The only real "mod" (and i use this term loosely lol) is to alter the bottom compartment to house x2 240mm rads. In stock guise the cosmos 2 comes with 2 HDD cages in the bottom compartment, however these are removable to make way for one 240mm rad. Coolermaster supply these 2 adaptor plates which allow you to mount a radiator on the two vertical support posts at the rear of the case.
I have managed to aquire a second damaged case for the price of naff all and plan to remove the support posts and fit them to my case which will let me fit a second rad and it all be factory fit with no bodging lol.
And just cos us men love "seeing how stuff works" i took the entire second case apart as it was just plastics that were damaged. Maybe ill look into painting this or doing something else with it in the future lol?
Think that will do for now. Apologies for the crappy photos lol
2500k i5
ASUS p8z77 board
sapphire 7970
Still working through some fan controller issues haha
