- 18 Oct 2002
- Xbox Live
Got a C2D e4300 on stock cooling in a ABIt Pro AB9 Mobo. I have set the BIOS CPU settings to auto, and it detected it as a 1.80GHz so all good.
at normal to low usage is hovers about 40 Degrees. I have been playing with Encase recently and tried to import a load of Hashs, this put the CPU at half load and the temperatures started rising significantly I let it get to 76 Degrees before killing the app and the temp immediately dropped. I tried running the hash import a few more times with similar results.
I downloaded Coretemp, Tat(which didn't work) and a few other programs to see if it was just uguru being a bit wet. But all the temp monitor apps seemed to indicate the same sort of problems.
Seeing as I see a lot of people on here have managed to significantly Overclock this CPU on Stock cooling and quoting similar temps to mine I'm a bit concerned.
I have removed the heatsink and removed the thermo-paste on the CPU/heatsink and applied some AS5 and am about to mount a 120mm fan in the front of my case. (Have a Antec Sonata III) So hope fully when I get home tonight and turn it all on it will be running cooler. However, if it is not what do you guys suggest. My planned next step is to get an Artic freezer 7 pro.
