11 Dec 2007 at 16:53 #1 hibeesmad hibeesmad Associate Joined 7 Sep 2007 Posts 400 Location Edinburgh I'm using core temp to show me my CPU temperatures (e6700) which my results are showing roughly 50 - 56c. What is the maximum temperature my CPU can handle and are these temps ok? Cheers for the help.
11 Dec 2007 at 17:01 #2 BillytheImpaler BillytheImpaler Man of Honour Soldato Joined 2 Aug 2005 Posts 8,720 Location Cleveland, Ohio, USA Are those temps at idle or load? At load that's a bit high but within normal. It won't damage the CPU.
11 Dec 2007 at 17:16 #3 hibeesmad hibeesmad Associate OP Joined 7 Sep 2007 Posts 400 Location Edinburgh When playing Crysis, the highest hit was 59c but was roughly about 57ish. Are you sure these temps are ok? I have ordered a new CPU cooler and arctic silver 5 so hopefully replacing the stock cooler the temps should come down a fair bit.
11 Dec 2007 at 17:44 #4 Mint_Sauce Mint_Sauce Soldato Joined 25 Sep 2003 Posts 3,750 Location Manchester That's fine, you only really need to be concerned at 65-70+. Although, most wouldn't want over 60 degrees.
