my cpu
27 Oct 2013
Hey guys recently i reset my overclock to try see something, how do i manage to get my overclock back what OCUK did for me. i saw it someone in my asus bios there is a file on cpu clocking called OCUK and i was just wondering if they have profiles saved or if you can have profiles saved in your bios to automatically set it back to the overclock. thanks!
look in profiles within the bios and load the ocuk saved profile,save/exit and you should have your oc back
After checking my bios my saved OCUK cpu profile has dissapeared now, i wonder if it has to do with a bios update what happend or if it had to do with reinstalling windows 7?..do you think if i ever take it back to the shop the warranty with the pc can make OCUK re OC my cpu again back to 4.4ghz?
