Hi guys,
I'll try keep this short and quick, hope someone here can help me.
As title suggests it's time to upgrade, and my mobo has literally started to fall apart.
lol
Now I looked into what would be perfect for me but there is just so much stuff out there I need the advice of someone who's allready been there and this seems like the place.
I wanted to go for the i7 920 but someone suggested to buy a Q6600 and just overclock it but then I came across the Q9650 and said to myself wouldn't it be better to overclock that as it's not that much more expensive.
Then the dilemmas started kicking in......
The main thing the pc will be used for is electronic music and that means running a lot of virtual instruments and these days most good ones are processor hogs! Native Instruments for example.
The pc won't be used for gaming etc. or much else apart from internet.
The host program I use claims it supports the latest multiple core technology so there would be no issues there.
My budget is £500 - £600
What are your opinions?
Your input is much appreciated.
lolNow I looked into what would be perfect for me but there is just so much stuff out there I need the advice of someone who's allready been there and this seems like the place.
