My custom gaming PC - HELP PLEASE!
2 Aug 2014
Hey :)
Here are a couple of tweaks.
The Raijintek should be quieter than the H60 with it's stock fans. If you want to overclock then the Raijintek is a good cooler.
You can maybe swap the psu for the modular version.
Both of those items will knock about £18 off as well.
YOUR BASKET
1 x SuperFlower Leadex GOLD 650W Fully Modular "80 Plus Gold" Power Supply - Black £77.99
1 x Raijintek EreBoss High Peformance CPU Cooler Black £29.99
Total : £117.58 (includes shipping : £8.00).
If you are not bothered about the 144Hz monitor then the rest looks ok. That gpu will cope with a higher resolution as well should you decide to buy a different monitor down the line.
Well, I wouldnt want to spend more than 1500 including delivery, assembly, etc.. so its still over my budget. Also 144Hz monitors are only good if you got games running at big FPS's with multi GPU's, for me the normal 60Hz one is more than enough. With my single GPU 144Hz wouldnt give the same quality as it should.
As I said your what you spend you cash is your choice I run a 144hz monitor off of the card in my sig and you do notice the difference not just in the frame rates, but how fast object show up (like in FPS).
Enjoy your new build :)
That might be my next upgrade then later on, but this time, the 24" will do :D
And a "tip" since a lot of people don't know. The acrylic that has the iChill DHS symbol on it for you to attach to the card is not scratched up. It's the protective film on it. Take it off and it'll be pristine.
Does the iChill logo and all light up well and look good too?
Is what it looks like it mine.
Nice, it will be nicer when its dark :>
Also, I will be getting the NZXT H440 case, do you think that the window on that will make me able to see my H80i's white light, the Inno3D logo, and the RAM's red lights perhaps? Does it show all the LED components inside the rig? :X
